Can anyone tell me which fuse I need to look at scania p420 07 reg. Interior lights ,typical handbook missing just when I need it,thank you,fuse number and voltage,cheers.
Try the back of the fuse box cover
fizza:
That is also missing,but Thanks anyway.
bobbya:
fizza:
Try the back of the fuse box coverThat is also missing,but Thanks anyway.
quality drivers there then if they have nicked the back of the fuse box cover
I’m in a 10 plate R440 but fairly sure the fuses should be the same…
Going from my own truck, try fuses 10 (5 amp) 31 (10 amp) 53 (2 amp) and the relay is RP5…
Hope this helps.
Can’t help you, I only know which one disables the tachograph.
bobbya:
Have you tried swapping the one that looks blown.
ironstipper:
bobbya:
Can anyone tell me which fuse I need to look at scania p420 07 reg. Interior lights ,typical handbook missing just when I need it,thank you,fuse number and voltage,cheers.Have you tried swapping the one that looks blown.
Very good but no lighting no see,nice one inspector morse
TruckingHell:
I’m in a 10 plate R440 but fairly sure the fuses should be the same…Going from my own truck, try fuses 10 (5 amp) 31 (10 amp) 53 (2 amp) and the relay is RP5…
Hope this helps.
Thank you all sorted now,nice for a sensible reply,cheers mate,it was number 10.
bobbya:
TruckingHell:
Hope this helps.
Sorry it was number 31,10amp
bobbya:
TruckingHell:
Hope this helps.
Glad to have helped out mate - all Stobart drivers are not tossers you know! - I’m excused from that anyway as I’m a soon to be redundant tramper for them…
TruckingHell:
bobbya:
TruckingHell:
Hope this helps.
Sorry to hear you,re being made redundant,I knew you could,nt all be tossers good luck to you,Bob.
