Right/Left Filter Lights
Do they operate the same sequence that usually on approach to a green and filter light lights a likely to quickly change to red so slow down. I know the right side filter light unsure about the left side filter light with green on.
Usually the filter comes on then the red goes to red/amber then green then both the filter and green light go back to amber at the same time.
I think
Sequence and timing depend on the junction, they will have been timed after observation, mostly to cause as much mayhem delay and congestion as possible :unamused:
Many modern traffic light installations don’t have a fixed sequence. They respond to traffic volumes and adjust themselves accordingly. The A5/A45 crossroads at Weedon is a good example that many will have seen when the M1 is closed between J16 and J18 - the sequencing of the lights (and the right turn filters) changes completely in response to traffic flows.
Sent from my Hudl 2 using Tapatalk
