Hi guys. I want a real good pair of LED reverse lamps for my trailer before dark nights kick in and I have to go on tight little farms!! Just wondered if anyone uses a certain type and would recommend them?
Cheers
Matt.
Cheers
Matt.
I’ve had some Hella FF model which are actually working lamps they have been on over 8 years never had a bulb in and never discoloured or let water in ( not led though ) .
You can just put led bulbs in regular lamp fittings.
I put a set of rubolite reverse lights on at last firm i was at, werent cheap but were bright
If they are the round rubberlite one s they filing with water .
What about standard back of cab connecting lights, nice little square ones that take a 60ish watt halogen bulb, even one of those would do the trick, a pair would be brill.
A key factor with these lights is that the cheaper lamps made of plastic are very weak / brittle on the mount to the metal bracket ,the Hellas don’t do this as they strong plastic with a rubber bush .
Denis F:
These are bright & cheap
Dennis to the rescue, wagons looking
Mint, saw you a few months back.
