Renault Premium 59 plate and power inverter problem
Hi just wonder if any one had problem with power inverter and Renault premium, got skytronic 24v 300w and everytime I connect to 24v socket it blows fuse on truck, the sockets are 24v 15a, trying to sort this as I can’t watch telly.
Thanks
Chances are the ciggie socket on most trucks wont be able to cope with that inverter,if you know what your doing wire it in directly to fuse box with in line fuse-failing that get a set of cheap jump leads cut one set of ends off then join wires to inverter,then connect to batteries.
Running that flat out calculates at 12.5 amps.
So I wouldnt have thought that a TV would have drawn enogh current to make it go pop.
You might want to get a torch and have a good look in the socket and just make sure that its nice and clean and that nothing is shorting.
Also just check your cable from the inverter to the plug? have you got a short? does it work ok in a different motor?
Hope this helps a bit.
