Has anyone got any idea why my unit is setting ride height way too low. Tried to manually set it but it keeps over riding me and I’m getting a warning on the dash and it start rubbing on my arches.
Anyway I can sort this easily?
bj86uk:
It’s to compensate for the attic being too high ![]()
sensor on your drive axle possibly… if you have a look you should see what looks like a spring coil and wire rod between the chassis and axle… it may have worked out of adjustment or be seized or bent… job for the experts though… in the meantime take the top bits off your mudguards, if you can, until you get it to the workshop…
Cheers mate you were spot on. Sensor and a leveling valve. Took the wing tops off straight away. Nursed her back to Renault.
