As an agency driver, I get no formal training on how to restrain a load, so I do what I think is best with what I’ve got, and find out if I made a mistake when I get to the other end. I’ve not anything fall off yet.
I’m doing curtain side work at the moment, and a couple of times I’ve been faced with paper reels.
Situation 1:
Reels stacked on end, approx 7’ diameter, 8’ high, 1400kg.
These were loaded up to the edge one edge of the trailer, alternating each time from front to back.
I used the internal rail straps on the sides which were up to the trailer edge, leaving the other side as they would be blocked by the 2 mating reels, and did an internal rail strap diagonally accross the back.
While I was doing this the next truck (different company) finished and I had to move to get out of his way, so whatever he did with the same load was quicker. Another truck from the same co. as previous showed, so I asked him as someone familiar with this load, what does he do? He replied ‘curtains only, with 2 diagonals at the back, vosa would be ok with that’. Given the width and weight of these reels I wasn’t too worried about this. I went on my way, but during which I had a moment of absence and chose a windy A road instead of the longer motorway. I arrived to find that the back reel only had moved to the other side of the wagon. Oh well, no harm done, try to do better next time.
What exactly is the capability of a curtain? (I know they vary) As I understand they have a rating (which I struggle to find most of the time) and if the load is against it, and is within rating it’s okay. So far I’ve light stuff without straps (often likely to damage goods with them) and heavy stuff use straps, normal ones if possible depending on weight and height of the load.
How does a curtain rating work? Is tons? or tons per length? or tons per area? or tons per strap?(the straps embedded in the curtain)
Situation 2:
Forky starts to load with 3000kg 5’ diameter 9’high. I’m quite worried about these, they can fall and shift and do serious harm. The forky loads the first one on the front, slightly off centre, and brings the second up to it, slightly off to the opposite side. This trailer has no internal rail straps, (its an opening top). With about 2" clearance between the reel and the ceiling. I make a futile attempt to get a strap over it, realise it’s not going to happen so I stop the loading, and tell the forky I’m going to seek advice. While I’m waiting for someone to ring back, the reels come off me, I close the curtains and get out of the way. I get a call advising me to request some step ladders to help me get the straps over. I go into the site office to be informed they refuse to load my trailer, as it is unsuitable without internal rails straps.
What a relief!!! off I go!.
The tractor units for this company normally carry about 12 ratchet straps, but NO corners.
Does anyone know how to secure the loads described?
I think if I’d had internal rails on the second one I would have put two on each of the sides nearest the edge, crossed over each other and more to secure the back reel. Would this work without corners?
Does anyone know good website or videos for this kind of thing?
I guess I should seek out a course (at my own expense
