Would these lights be legal, or not legal ?
And if not, why not ? (Strictly speaking of course)
The answer may be in here -
opsi.gov.uk/acts/acts1988/uk … 80052_en_1
Not really ROG.
That’s a link to an Act (of Parliament) that simply says that the Secretary of State is empowered to make regulations.
The answer would lie in a specific, and particular regulation. Normally known as a Statutory Instrument.
Remember - I did say
I would say these would be legal as long as the replacement is eMarked correctly.
Both lamps have a built in reflector which is compulsory and cannot see a reason why an LED and a standard tail lamp shall not be used.
I wait to be edumacated. ![]()
dambuster:
This any better:
opsi.gov.uk/si/si1989/Uksi_19891796_en_1.htm
I would say these would be legal as long as the replacement is eMarked correctly.Both lamps have a built in reflector which is compulsory and cannot see a reason why an LED and a standard tail lamp shall not be used.
i am no Electrician but i thought an LED requires a transformer to power the lights can you have the two systems running in parallel
delboytwo:
Dunno matey, but the side markers on our Schmitz trailers were led as were the front marker lamps but the rear lamp units needed bulbs.
I don’t know for certain, but I think they would be perfectly legal, provided they both operate correctly.
As far as I remember, a trailer needs - two rear facing triangular red reflectors
two rear facing red tail lights, close to the outside edges,
two rear facing red brake lights,
two rear facing orange indicators,
a red high intensity (fog) light.
side marker lights and reflectors
a white reversing light is optional I think, and must not be on when the vehicle is going forwards.
I doubt that the legislation would say that both light units have to look the same.
Its a visibility/safety thing, not a cosmetic/prettiness thing.
Those links probably do have the answer ROG, but as you supplied them, can you translate them into laymans terms, because I can’t figure out what they say unless I sit down for a couple of hours.
Road Vehicle Lighting Regulations S.I. No 1796 of 1989
Schedule 11
Section 12
http://www.opsi.gov.uk/si/si1989/Uksi_19891796_en_16.htm#nsch11
- Other requirements-
Where two rear fog lamps are fitted to a motor vehicle first used on or after 1st April 1986 or to a trailer manufactured on or after 1st October 1985 they shall form a matched pair
It’s the same bit that says you can only have two (one pair) on newer (than 1979/80)
Elsewhere give the definition of “matched pair” to say they have to be the same colour/size/shape, but strangely not about the intensity or wattage.
delboytwo:
Not on a trailer they don’t, as the units are designed to work on 24V the same as the normal cluster, they’re completely interchangeable.
On the original question, I would say it’s legal. I don’t think there’s any requirement in law for the lights on the two sides of a vehicle to match.
Paul
dambuster:
Schedule 11
Section 12The Road Vehicles Lighting Regulations 1989
Where two rear fog lamps are fitted to a motor vehicle first used on or after 1st April 1986 or to a trailer manufactured on or after 1st October 1985 they shall form a matched pairIt’s the same bit that says you can only have two (one pair) on newer (than 1979/80)
That suggests only the fog lights have to match, so if you disconnect the nearside led it would be legal, then again if it is a foreign truck what would the driver class as offside ![]()
It would be easier just to take the bulb out of the other one (or change it for a blown bulb).
These light units have a single waterproof multipin plug and socket, I think, so disconnecting one part wouldn’t be that easy.
