Prima Frio.
Surprised you saw those wings folded up…
My first thought was DRS system akin to F1 cars to help overtaking. Obviously wouldn’t be active on the first lap or under safety car conditions, but every little helps. (See what I did there BB?
the maoster:
My first thought was DRS system akin to F1 cars to help overtaking. Obviously wouldn’t be active on the first lap or under safety car conditions, but every little helps. (See what I did there BB?)
Franglais:
Prima Frio.
Well it was rush hour near Dartford so was never going to get much speed up anyway although he did get them open for a few seconds but like I said certainly not seen them before.
Can honestly say I’ve never seen/noticed them before ever ![]()
What’s the purpose? I’m assuming aerodynamic improvements allegedly? For fuel consumption improvement?
Open wings, back on bay close wings around bay, bit similar to the air bags on the bay, ment to keep things cooler when on bay, leaving fridge running to keep it cool.
biggriffin:
You don’t back onto bays at 80+ km/h on the Motorway…
Sent from my VOG-L09 using Tapatalk
biggriffin:
They only opened up when the driver briefly got up to about 35 to 40 mph otherwise I’m assuming they stay shut.
Here you go, I know nothing about it but they’re obviously pushing it from a green angle.
I have an idea. Put the whole truck inside a giant baloon. Inflate and seal. Now all you have to do is figure out a way to make the baloon rooll with the truck inside, that way there is 0 wind resistance on the truck+trailer.
ps. It says CO2 reduction on the flap so it must be true
Strange they go to that expense when the average N. American tractor unit seems less than aerodynamic.
Sent from my R19 using Tapatalk
If its designed to make it go faster, the truck you saw must`ve been on Irish plates ![]()
peirre:
Paddy be lucky to keep up with Primafrio and delchov at the helm.
They have just had delivered 300 new FH to replace 300 DAF, all Portugal registered apart from a smattering of Spanish plates that can drop and pick up from rail heads.
In a previous life called paconsa. How do they get away with it? Loads of Mozambique drivers working for buttons, poor b’strds…
I wonder how you would fare with kit like this deployed if Mr VOSA was having a slow day and decided you were exceeding your length limit for the vehicle?
WhiteTruckMan:
I’ll bet there is some variations written into C&U regs? . Same as having Eu6 cameras in windscreen.
WhiteTruckMan:
How would they measure it? By the time they’d stopped you and run a tape measure over it the length would be fine… [emoji848]
Roymondo:
WhiteTruckMan:
I wonder how you would fare with kit like this deployed if Mr VOSA was having a slow day and decided you were exceeding your length limit for the vehicle?How would they measure it? By the time they’d stopped you and run a tape measure over it the length would be fine… [emoji848]
Good question. I dunno. Might be enough to have dashcam footage of it deployed in motion, then pull the vehicle and measure it.
