Hi all just joined and would like to ask some things been to scania and got my self a hub socket for the mid lift axel it has 0-30 marked on the side I think it could be degrees any thoughts also I need to do the king pins on the mid steer lift axle never done one before any advice would be greatly appreciated thanks Isambard
I’ve moved your post to where it is more likely to get the answers you’re looking for. dd.
isambard:
Whats ya chassis number ill have a look on scania multi ,How much did scania charge you for the socket£££££££ what size is it,av y got a pic.
Hi thanks for moving it to the right place the price was £85.00 for a 100mm socket it was cheaper then e bay I will have to get the number and post it sorry no photos but do not know how to do that
Old scania kingpins up to 04 used to be taper pin and roller bearings with various size of lift shim.
Dead easy to do as opposed to stupid bloody parallel pin and bush settups used by our german collegues.
