power adapter
anyone got/use/recommend a 24 to 19 volt dropper for my lappy.where can i get one and how reliable are they. i have seen a smallish on (■■■ packet size) but not sure if its good enough
thanks guys
These seem to be pretty good, although not cheap.
I use one now, after finding out the inverter I used before it was causing interference with my MAUT sensor. It doesn’t cause interference with my CB either.
Why not use an inverter? I use one all the time, saves a lot of messing about and you can run any other mains stuff providing you dont exceed the maximum wattage. Mine is 300 watt but you dont need anything like that for a laptop.
im using an inverter at the moment but was looking for something a tad smaller and less wires etc. fussy i know but
well may as well look but ay those prices simon i think i will stick with the inverter, cheers both for your replies.
Well i just bought one of ebay 24 volt with different voltage settings and recommened for laptops etc.
£24 delivered to my door. hopfully it will eo the job
