the maoster:
^^^ might I respectfully suggest a module on tachograph regulations for your next DCPC? If you are going to advise someone on legalities the ramifications of incorrect advice can be potentially expensive.
Where do you get 6 shifts from? Where do you get 25 hours from?
You may reduce a weekly rest from 45 hours to 25 hours but the third week you must then take a full weekly rest.
There’s plenty of people who are working six shifts, take a full 45 weekly rest, and then start another six shift block staggered by one day per week, gradually rotating over all days…
The 5-6-5-6 pattern - is also well known.
5x12 hour shifts in week one, and 6x10 hour shifts in week two. You take a 45 hour weekly rest at the end of week one, and can reduce to the 25 hours weekly rest at the end of week two.
“Reduced daily rest” kicks in once you’ve done 13hrs 1 minute in a single shift.Sensible people make sure they rigidly book off as often as they can BY 13 hours into a shift, so they don’t keep dipping into those 3 reduced rests permitted. They are to facilitate full rest blocks of time between shifts NOT a warrant to “insert overtime at every opportunity, because your hourly rate is too low to get by otherwise” which seems more common the further north you go in this country…
Outfits like Royal Mail would limit everyone’s hours to 48 per week average over a 26 week reference period, which is an overkill of the regulations. How do you think people get 60 hour and even 84 hour weeks in, perfectly legally at many other yards… I think the “10 hour shift maximum on nights” still applies as well, although I stand to be corrected (rather than just called ‘wrong’ without the correct answer from the critic being provided…)
Don’t forget also, that the time you clock in is the time your hours start, NOT the time you insert your card.
Time spent on break/POA is still time spent at work, as you are not free to dispose of your time as you wish.
A 12 hour shift therefore - should be inclusive of paid breaks, and not be like outfits like RM who would have you working a 13.5 hour shift with 90 minutes deducted for unpaid break, meaning you get paid for 12 hours, but you’ve also used up one of your reduced rests that week… What a con!
