Good morning.
Can anyone please help me?
I have to drive either a Day XF or Iveco NR over the weekend but there won’t be anyone at the depot to ask, just keys left with security.
Cant find the info on google so can anyone please tell me how I can do my oil and coolant checks on these 2 vehicles.
Many thanks in advance
somtam:
Good morning.
Can’t help with iveco sorry, but for daf xf (depending on year). Oil level is checked using on board computer, two different types…one has a single black wheel with a button in the centre. Other has same but a button with a backwards arrow. Once ignition is on stage two (but do not start engine!) use the wheel and buttons to scroll through the menu. Look under vehicle info and then oil level. If the engine is still warm it won’t get a reading (unless it’s a newer type which will show you the last reading it managed to get).
The coolant checks itself using a sensor, but check manually, bonnet catches are either under the bonnet itself (feel behind the panel at either end, or on newer models there is a lever on the passenger door step (put your had on the metal plate of the top step then feel upwards!)
Sent from my LLD-L31 using Tapatalk
Iveco NR
Lift the front flap with two hands - screen wash and radiator tank to the left.
Oil dipstick also to the left - mine has a green top. About as simple as it can get -
