Yes, I was. I missed a comma out then created confusion.
Goldilox:
Donāt worry I donāt use punctuation
Why donāt you just go do your C
Goldilox:
Just checked my licence and if I am reading it correctly I can drive C1 D1 and C1E. Canāt think the C1E is right as the little picture looks like a wag and drag!Hmmm,free assessment drives, sounds good
I didnāt realise the term puddle jumper was derogatory - thought it was an affectionate nickname,lol
The units arent that bad, its the drivers. That being said, my best job (so far) was in a 7.5t.
Probably best thing to do first is get my medical then decide in the meantime. I had looked around for trainers a good few weeks ago, then looked at them on street view.
Thanks for input.
Nowt stopping you going to visit a few trainers there are some here you
So, to sum up⦠I would definitely need a medical regardless of when I took my test and regardless if it says C? ( canāt remember what I put now as I canāt look back from this reply box) and regardless of not even wanting to take the actual test?? The provisional. I think I told Mr Tachograph that I am included up to 7.5T. Does that mean UNDER or actual?
Sorry about any dimwittery on my part - just that I donāt want to shell out on stuff I donāt need, and I would like to crack on with this.
What about the types of vehicles the trainers use? I would prefer one where the seat would go quite high as I wouldnāt want to be looking through the steering wheel - exaggeration I know, but I would like to be high up as poss. Also, years ago I had to drive 2 white vans in one week. One of them was a Merc ( I think) and I remember sometimes having to use 2 hands to change some gears and the other one was a Ford and it was much better than the Merc. Or was is the other way roundā¦
On the assumption youāre a blonde Goldilox, youāre starting to give even them a bad nameā¦
Remember if you sit high up you will still have to be able to reach the accelerator & break
I drove vans for a long time never had a problem changing gear & drove quite a few
As some members know I am not that tall & donāt have a problem driving CE so just go for it find a good trainer go talk to them ask if can sit in the vehicle see how you feel
There will be some near you or you may have to travel not that far though as I went from Newcastle down to Chelmford for my test as I used John Flair training ( he is a member on here ) there are also several other trainers on here you could ask if you can go visit just a though
Just get your C done and dusted.
Not convinced the OP actually intends doing anything!
Pete
Goldilox:
So, to sum upā¦I would definitely need a medical regardless of when I took my test and regardless if it says C? ( canāt remember what I put now as I canāt look back from this reply box) and regardless of not even wanting to take the actual test??
As far as Iām aware, even though you have cat C1 on your licence you will need a medical to drive a cat C HGV on a provisional licence, Iām sure someone will say if thatās wrong.The provisional. I think I told Mr Tachograph that I am included up to 7.5T. Does that mean UNDER or actual?
Cat C1 which is what you should have on your licence is any goods vehicle not exceeding 7.5t and you can pull a trailer up-to 750kg.
Cat C1+E which you should also have on your licence is a goods vehicle not exceeding 7.5t with a trailer that can be over 750kg, however the code 107 restricts you to 8.25t gross weight.
Didnāt mean to procrastinate, Pete Iām trying to cross the iās and tās for myself so to speak, and I have been reading up a bit on the stickies also ( something about drains on roundabouts
) So now I can get done and dusted, or should it be dusted and done
Thanks animal for sharing your views on vans, gears, etc. and Tacho for the techy bits.
As for you Beezle, well, I donāt know what to say, as I thought you were a laydeeee who drank pink gin ( or was it blue?) Also try and remember that gold is not the same colour as blonde; now go and make a coq or van to go with your Gordonās
I didnāt realise his boyfriend was called Gordon.
Shhhh, we donāt want āyou know whoā to find outā¦or do we? The K word!
Is that Gordon, Radar?
Rubbish lip liner job, if I may say
I have no idea whats going but Iāll leave this year.
Goldilox:
Got my drink right here!
The sad part is, thatās really my mug!
