Hi when doing non tacho driving and tacho driving in a fixed week , iknow you have to write either write on a chart or printout but what mode would you use on the tacho when doin a manual entry to cover the non driving day the next time you use it , even tho uv been working ? Thanks
Jasonp:
Hi when doing non tacho driving and tacho driving in a fixed week , i know you have to write either write on a chart or printout but what mode would you use on the tacho when doin a manual entry to cover the non driving day the next time you use it , even tho uv been working ? Thanks
No need to do anything as you have the info on an official record
Thanks rog for the reply .bit what i was trying to get at was if you are driving truck 1 day van the next the truck again could you use the ? Symbol ( newer tacho) or the break to cover that van day ? Cheers sorry if i sound stupid
Jasonp:
? is fine as long as other official records are made
Thank you
If I was driving truck day 1&3 van day 2 I would use other work?
I do use the. ? But only if it’s been a few weeks in between inserting a tacho and too many manual entries of OW to enter. I Just keep a manual record as a back up.
(I believe this is ok.)
No need to repeat yourself, we got it first time
Toddy2:
No need to repeat yourself, we got it first time![]()
Doh!
spacemanZ10:
Toddy2:
Doh!
hmmmm… SORTED ![]()
