JAKEY:
I had all my vans /trucks fitted with night heaters , even a day cabbed sprinter , saves money in the longrun .
how dose a 12volt van run a 24v night heater?
JAKEY:
mcgregors shafter:
JAKEY:
I had all my vans /trucks fitted with night heaters , even a day cabbed sprinter , saves money in the longrun .how dose a 12volt van run a 24v night heater?
You can get 12v heaters as well as 24v.
Pat Hasler:
mcgregors shafter:
your cab is just a metal tin; get some tar-poll sheeting or a market trader sheet and cover the cab out side with it
most of the heat is loset through the glass so if you can get some bubble wrap and card and cover them inside and out sideand one of those camper gas heater put next to the window with the window open
Many years ago my night heater packed in and I happened to have a camping stove with me. I awoke one morning at a truck stop in the north of England freezing my goolies off and lit the stove just to take the chill off… Next thing I knew I was in a hospital recovering from Carbon monoxide poisoning.
DAF95XF:
My coach has a Webasto night heater fitted to it too, so not just vans and trucks that have them
Technically, on a coach that is is called a “sanitising heat evaporator”, and is designed to burn off the smell of the old folks’ urine. ![]()
mcgregors shafter:
JAKEY:
You fit a 12v night heater.
You can also get Webasto heaters for small boats.
mcgregors shafter:
JAKEY:
Harry those night heater draw a lot of current
would the convetor box in your pix handle the amprage?
Probably not the one in the pic, you would need one suitably rated.
i dont like night heater and nor do bosses
and you can understand why…batterys…
No, I’m afraid I don’t understand why, a night heater won’t discharge a healthy set of batteries even if you leave it running all night, it uses a fair amount of power until it fires up, after which all you are doing is running a fan.
mcgregors shafter:
It uses sod all electrons and sod all motion potion, I love night heaters especially when its -10 outside.
threewheelsonmywagon:
a brand new 8-leg rigid complete with a seriously large Hiab
That sounds expensive. How much more to have a night heater installed
