caledoniandream:
LRM:
I think i would go with billybigrigs advice, I was thinking the same myself…
“back on uk work soon enough”
Lrm
I would not, you can always retrofit one of these small pusher axles, even under a short chassis.
You can imagine the French gendarmes getting a stiffy if you run with 6 axles on the Tarmac, they know straight away that you are overloaded.
It gives it away there and than, asking for problems.
Can load a ton more without the mid lift, so it cannot be that difficult.
Also a (I hate French trucks) premium or the MaN are substantial lighter, this is the only thing that counts in bulk transport.
Dealer network for Renault is very good in France and Spain.
But IT’S gives a superb service for Daf
If I would do it, light truck light trailer, lift axle on the trailer with operation in the cab, so that you can lift the axle before you can go in the peage (works only in the automatic peage if you have a box)
Well I’ve run all over the place in 6 leggers and as far as the Gendarmes etc are concerned, not once has the extra axle caused suspicion of overloading. In fact many times the opposite effect has occured. When the Gendarmes used to hover at the Nantes peage with the axle weigher, they would often spot our 6 leggers and knowing fullwell the drive axles would be OK pulled us out of line and waved us off
Good job really
Loads of Brits run 6 leggers without sticking out from the crowd and always have done. Cheltenham airways, Superfullobollicsfridgelogistics, Pulleyns, etc etc etc
Also if they lease a 4 wheeler and slap a set of stablilisers on it, I wouldn’t see the lease company being massively impressed.Not to mention it’s not as cheap as you’d imagine when you take into account you’d need new fuel tanks etc and then have to re plate it and then return to standard when it goes back. A little more plausible if you buy the unit granted
I also suggested a standard 6 legger as it would be more flexible within there own fleet when/if it isn’t in Spain. Remember that the axle positions on newer 44 ton trailers make it difficult to pull them with a 4x2 and not overload the pin at 40ton unless you load them carefully.
Also, with no disrespect to the poster, when an operator inexperienced in this particular area who’s quoted via calculator rather than knowledge and experience often gets a big shock when the hills eat the predicted diesel and time like a fat chick at a buffet
Not to mention the constant interruption of the perfect one a week scenario by holidays and other such things.
All in all, good reasons to lease a UK friendly spec lorry
Well I’m off to sit quietly in the corner while the pedants, the enraged and the google experts get going
