New driver and anxious
No pages of adverts both employed and agency,mostly trying to fill vacancies for local multi drop/retail/building deliveries/labourer/driver jobs,while two drivers turn up for one distance,5 drops per shift,all fork lifted,job says something else.
No it doesnt. It really, really doesnt.
2 drivers turned up because the agency sent 2 drivers for 1 position, no other reason.
Whether theres a driver shortage or not I have no idea (and frankly dont care enough about it to spend my life going back and forth with you about it) but what I do know is taking this one example and holding it aloft as proof that there is no shortage is hilarious.
Unless you think that no drivers out there want local work or are willing to do anything manual and every single driver only wants distance work with nothing more taxing than opening the back doors to reverse onto a bay.
I cant work it out what it is youre claiming because as usual, youre all over the place
Unless you’re blind and deaf or just can’t read.
I can read just fine but some of us live in a world where you read whats actually there, not just what we want to see
The-Snowman:
No the agency didn’t it really really didn’t.
It sent 1 driver a cancellation e mail and sent the other driver instead.The other driver didn’t get ( ignored ) the e mail.Both drivers turned up for the job.The OP seemed rather keen to do it to the point of calling ‘favouritism’ and thereby obviously implying collusion between the other driver and the client manager ( probably correctly ).Trust me that doesn’t happen unless both drivers really really want to do an attractive job to avoid doing something less attractive.
Bearing in mind that I experienced something similar myself ( being removed from a similar even better distance bulk pallet job and put back on local building/retail multi drop zb for obvious reasons in being seen as a mug ).To the point of finally deciding to walk away from the agency.
Ironically in this case my gut feeling being that it was the other driver who was stitched up here not the OP just as I was.IE similar attractive work,similar message of unexpected cancellation and the client having told me that he wanted me to stay on the job long term.
I do love how Carryfast reckons he knows the exact ins and outs of every job in this industry despite not working for the past two decades :smiley:
switchlogic:
To be fair the scenario described by the OP is suspiciously as close as makes no difference to my own experience a lot more than 20 years ago.Similar type of job,similar type of out of the blue cancellation,probably similar reasons.The difference being that in my case it ended there.I didn’t go back to the client anyway to argue about it.Although phone cancellations weren’t as easy to ignore as e mails would have been in that regard. :smiling_imp: We really need the ‘other’ driver’s side of this story. :bulb: :wink:
switchlogic:
He’s a boring ■■■■
Rjan:
Make your mind up.Firstly you’re saying that LHV’s,in addition to removal of road fuel duty,would create less jobs for truck drivers.Then you’re saying that the move would obviously actually create more balance regarding the long haul road freight sector v rail thereby actually creating a net increase in truck driving jobs and in the quality of those jobs.
I said LHVs will reduce the ratio of drivers required against volume of freight carried. That is the whole point of LHVs, and surely it is an uncontentious point?
I didn’t say cutting fuel duty will reduce the number of drivers required.
I accept obviously that if you reconfigure the parameters which determine the relative competitiveness of road and rail, in road’s favour, then more freight is likely to be moved by road.
What I don’t accept is that more freight will mean higher pay or better conditions (except, as I’ve said, perhaps briefly during the initial disruption caused by the change, if such a spike was not forestalled by measures designed to prevent it).
If higher volumes of work for a sector necessarily meant increased pay, then doctors would be on poor pay and factory workers and call centre clerks would be on good pay.
On that note it seems strange as to why you’re conveniently all for taking truck drivers’ jobs and replacing them with far fewer train driving jobs.While at the same time trying to hypocritically make the case that LHV’s mean less truck drivers’ jobs but which you know is bs anyway.
I’m sure we’ve had this argument before. I’m not “for” rail freight in some partisan fashion, I simply accept that it is technologically suited to the task of long-distance, high-volume freight.
My response is fierce because of the idiocy of your general reasoning together with the beady-eyed enthusiasm with which you propose to intentionally smash another man’s industry simply to cannibalise their work. We are already swirling in the cesspool that such thinking creates.
I would be just as fierce if you said let’s introduce LHVs, abolish fuel duty, and carry petrol in drums, and in this way we can improve pay and conditions in the sort of work to which you confine yourself, by taking work away from those better-organised petrol tanker drivers.
Or indeed, let’s abolish the national petroleum and gas pipelines, and replace them with movements via road haulage.
The obvious economic absurdity of such arguments, and the resulting infrequency with which one hears them, leaves one stuttering to analyse and articulate their flaws.
Don’t see anything within your reasoning which isn’t just all about lumbering truck drivers with mainly dumbed down,boring,job options,often involving ridiculous levels of ‘other duties’,just to protect your chosen few in the form the rail unions.The result being drivers voting with their feet.Hence a shortage of and an oversupply of drivers for,‘the right work’ and a surplus of and shortage of drivers,for ‘the wrong work’.Which will only get worse while we continue with the cross Party anti road transport consensus committed to returning the industry to its place in the 1930’s and before.
Your own ideal job - the RDC trunk - is the most dumbed-down and boring of this industry.
There is no shortage in any division of this industry. There isn’t an imbalance either. The driving-with-labour roles just involve more fly-by-night firms who burn through drivers faster, often going through every available candidate in an area like a dose of salts, until they either have to sub the work out at higher rates to those who can retain drivers, or return the contract to source and allow it to be taken over directly by those who charge more and who organise the work so they can retain drivers.
To anyone who ever says they cannot recruit a driver, ask them, have they tried standing in the carpark of one of their competitors in the evening, and offering to beat both the wages and conditions, paid for by clients desperate to get their goods moving? If they cannot afford to do that, and there are no desperate clients willing to bankroll the scheme, then there is no shortage.
Lots of bosses only imagine they have a shortage. “If I could get 10 more drivers, I could steal this contract from Bloggs Ltd down the road”. But Bloggs Ltd already has the 10 drivers doing that work. No actual shortage of drivers exists, rather there is a surplus of bosses and firms all scrabbling to capture the same work, which is already being performed by an adequate number of drivers.
multi drop work is the no.1 top for your physical well being imo you never see a big bellied sort doing it.
It sent 1 driver a cancellation email and sent the other driver instead. The other driver didn’t get ( ignored ) the email.
Uh huh. And has anyone actually seen proof or at least verified this email even occurred? You don’t think its much more likely that the agency didn’t want to admit they cocked up and claimed to have sent a cancellation email?
I find it very hard to believe that
  1. An agency cancelled a shift via email instead of text or phone call.
  2. That,if that did happen, a driver will just simply ignore said email and turn up for the shift anyway (bearing in mind he would have no idea it would be him kept on and the other guy sent home or even if there was a shift for an agency driver at all and that the client didn’t need a driver after all) and
  3. that even if the above two DID happen, the agency will pay the driver they told, with plenty of notice, not to turn up and refuse to pay the driver they did want to turn up, who turned up in good faith.
Trust you? Based on your understanding of an industry you haven’t worked in for 2 decades? When a few days ago you actually advised the op not to chase the days lost wages as a sign of good faith in the hope it would lead to a weeks worth of work further down the line?
Nah you’re alright thanks. You’re a tad too out of touch for me to place faith in your conclusions
The only way two drivers turn up for one job isn’t to avoid something less attractive, its because neither of them got cancelled.
No one, but no one, gets out of bed at daft o’clock and turns up for a job that starts at 6 in the morning unless they are sure the position is there and they’ll be getting paid.
yourhavingalarf:
People stopped…
Reading this thread about 4 days ago.
I wanna know where scottie gets the bell end smilie from? It really should be in with the standard smilie range we have here.
If you use tapatalk, you can use the emojis from your phone,
[emoji348][emoji773] [emoji106][emoji12][emoji352][emoji774][emoji776][emoji336]
Sent from my LYA-L09 using Tapatalk
The-Snowman:
I agree generally. However…
If the experienced fella was a regular fixture in the place, and was reassigned at the last minute being told there was nothing available at this regular gig, but felt there was some shenanigans going on with the agency, that could provide the motive for him to turn up on spec to see what’s going on and see whether he had been replaced.
It’s not clear what the agency’s motive would be in such a case, but perhaps that the regular firm in question was willing to take a new driver and the other (to which they sought to reassign the experienced driver) was not.
Perhaps the experienced fella refused the alternative, but the agency then felt they couldn’t go back on the lies they’d told to the experienced fella, so left the arrangement with the new driver going into the regular place for the day. Perhaps also the alternative offered to the experienced fella had a later start time and was nearby, so he had the chance to pop in to his usual place beforehand.
But then when the experienced fella turned up and discovered the situation, the agency felt it better to prefer him than the new driver, and just tell everyone there was a clerical error.
This series of events is not entirely far-fetched in my view, so it’s a possibility that cannot be ruled out. It’s certainly the sort of intricate-web-of-deceit explanation that Carryfast always prefers to believe, as he does with the faked moon landing.
But I agree with you that the simpler and at-least-as-likely explanation is simply that the agency became confused and told two drivers to turn up for the same shift.
Most agencies are staffed by those whose relationship with the truth is loose, but their handle on administration is often just as loose, and there is some correlation and cross-causation between the two factors because it’s very difficult to keep track administratively of all the yarns that have been spun and half-promises made, especially if it’s all done on the hoof, and by multiple people representing one organisation.
That is, although the root cause of the problem is always a habit of dishonesty, adverse administrative outcomes are often the unintended consequence of struggling to manage their own dishonesty and keep their administration in order at the same time, rather than all “mistakes” being the expression of a specific dishonest plan that was unexpectedly foiled.
