gothika:
i have most of the basics and understand them read all drivers hours and wtd regulations but still not 100% on some issues, i,d be grateful for all your help as i don,t want to get fined or anything once i pass my class 2 and start work.
below for driving & wtd are only examples just so i can get the legal stuff, as i know its not all driving
question 1-- speed limits for class 2 & 1 trucks
on a single carrigeway national speed limit small signs can i do 40 mph
on a dual carriway national speed limit large signs can i only do 50 mph
on motorway can i do 60 unless speed limiter only allows you say 56 mph
As already answered.
gothika:
question 2 – i know you can split 15 mins the 30 mins but say after driving 4 & half hrs i have break 45 mins then drive another 4 & half hrs in total if i want to drive my extra 1 hr which is twice a week do i need to have another break of 45 mins after 9 hrs before driving that extra hour
Yes with the example given you would need another 45 minute break.
The maximum you are allowed to drive is 4 and half hours then you should always have a 45 before doing any more driving, unless you’re splitting the break of cause, but you seem to understand that.
gothika:
question 3 – if i drive 4 & half hrs then break 45 mins then drive 3 quarters of an hour this is 6 hours do i have to have a break of 30 mins wtd or is this cancelled out because i had 45 mins driving break
The 45 minute driving break counts for the WTD as well.
For WTD purposes you shouldn’t work more than 6 hours before having a 15 minute break, but in the example you’ve given you’ve included the driving break in the 6 hour period, you’ve only actually worked for 5.25 hours not 6.
gothika:
(((or if i 4 & half hrs then break 45 mins then drive plus other work for another 1 & half hrs do i have to have a break of 30 mins wtd or do i not have to because i had a 45 min break
Same as above, any breaks for driving count as breaks for WTD purposes also.
gothika:
question 4 – the max working hrs is 60 hrs a week is this for 5 days or 6 days, example say if i am working 3 of 15 hrs & 2 of 13 hrs(( driving & other work & breaks)) this is total of 71 hours. if it was mon till fri night and i had breaks say my driving breaks 45 mins x 5 days = 3 & 3 quarter hrs + poa 5 hrs & 2 & a quarter hrs in other breaks this should be 60 hrs have i got this right.if the 60 hrs is for a 6 day week how will it work out for a 5 day week
Sorry I’ve just finished a night shift and can’t get my head round this at the moment.
The maximum you’re allowed to work in a week is 60 hours, this is actual work excluding rest/breaks and POA, weather you do it in 5 or 6 days is irrelevant as long as you also have the necessary breaks and rest periods including a weekly rest or reduced weekly rest period.
The 60 hours a week have to average out at no more than 48 hours a week over the reference period (usually 17 weeks).
gothika:
question 5 – poa if i don,t know how long it will be before they unload me can i put it on break or is that illegal, if so whats max time you can do this.
You can legally have a break and put the the tacho on break as long as you’re not doing any work and the time can be spent to recuperate, or you could put the tacho on other work which it is really unless you’re on break.
As far as “max time you can do this” is concerned, I’m not sure what you mean, you can put the tacho on break any time you have a break, there’s no limit, but if you’re not on break or POA whilst waiting to load/unload then it’s really other work.
It should be noted however that if you put the tacho on break every time you stop it’s going to look quite suspicious I would have thought, If you got stopped and VOSA saw that you put the tacho on break every time you’re waiting to unload/load I imagine it may raise suspicions and encourage a closer look at your records, but I’m guessing at that
Hope I’ve typed this so it’s understandable
