raxore:
Having passed my class 1 in November I finally got a job doing general haulage tramping, starting last week, this proved fairly difficult to get a job in my area of the country and only being 22 so I took what was offered anyway…
Coming towards the end of week 2, is it to early to question whether tramping is for me? Or if driving work in general is for me.
This may be down to the amount of sleep deprivation I have endured due to finding it very hard to get a full nights sleep in the lorry and obviously the very early starts which I am not yet custom to.
Everyday I feel like I learn something new, which is obviously good right but equally I feel like I’m doing the job as effectively as others. Keeping to the times given by the office and keeping within the hours of work you can do seems a tricky balance.
On the whole other drivers I’ve met on the road and abouts the last couple of weeks have for the majority been fairly helpful and I’m always grateful for advice.
Ultimately my days are full of ups and downs, small victories like getting onto a bay without much fuss or even on time! Then downs where I feel as if I’m lagging behind and forgetting to do something or just being generally not very good.
Obviously most of this I’d imagine comes with experience. Just wanted to know what you more experienced folk thought, and if any of you felt similar when you started.
Thanks.
Sent from my Nexus 4 using Tapatalk
Every new job type takes time to learn.The manouveres like reversing and getting in and out of tight spots WILL become second nature through time…trust me on that.
As for tramping.
If you even attempt to meet tight or nearhand impossible schedules set from.day 1, you will get them all the time.
Do not allow yourself to be pushed, it will only end bad , coupled with the more you get flustered being new.
Set your own sensible pace, do NOT drive tired and do not look upon breaks as something you have to ‘get in’ …use them to freshen up, have a kip or a coffee or both.
You use the phrase ‘sleep deprivation’ that is tired x 10.
Do you HAVE to start at the times you are?
What do you call ‘very early’ ?
The earliest I ever start is 5 to 5.30 and I still get the job done.
Do the job as best you can, do NOT to try and keep up with the ‘Superstar knob heads’ on your firm, …the 2am starters who run the limiter all day and park up on 8.59 everynight to ■■■■ up to the boss, and make a name for themselves
(unfortunately for them the name usually starts with ‘C’ ) …I’ll guarantee you will have them on your firm…(just ignore any ‘advice’ they give you also, it will all be ■■■■■■■■)
Keep your distance from them.
Explain to your boss your concerns, remind him you are new, and if he is a reasonable guy he will have a look at your schedules and workload.
I’ve done tramping a while mate, it can be a great job, or a total pain in the arse, but that is determined by how YOU approach, do, and carry it out.
Do not make the mistake as a lot do, by turning it into an endurance test or it will be hell for you.
If it was me I would give it a bit longer, and decide after getting more proficient at it …and taking good advice.
