How does moving trucks in and out of bays with no digi card inserted in tacho sit within the scope of driving time rules?
Is it allowed?
Is it allowed?
smiggs:
How does moving trucks in and out of bays with no digi card inserted in tacho sit within the scope of driving time rules?Is it allowed?
insufficient information … is it you before or during your working day or a shunter…
After the working day and my tacho is pulled
Can I then move another truck or 2 onto bay in order for it to be loaded without it being recorded on a tacho is it legal or otherwise?
smiggs:
After the working day and my tacho is pulledCan I then move another truck or 2 onto bay in order for it to be loaded without it being recorded on a tacho
Technically you should use the card with the tachograph on “out of scope”, the time would be classed as other work.
If it’s just a matter of minutes and you don’t want to insert the card you could do a manual entry the next time you insert it, the time should be recorded as other work.
tachograph:
smiggs:
As Tacho says just watch your driving time if your running tight to hours
