Module 4 question half loads
Hi guys. Should get a date for mod 4 test in bout week and im abs bricking it. Want to get this done as money there for class 1, regarding the questions on half loads. Do they all go up against head board. Steel plates. Palisted paper. Cages etc? Any help apprecated guys thanks. :smiley:
Palletised Paper - Load evenly across truck from around the rear axle forwards.
Steel Plate - same as above
Empty cages - Load against headboard
Don’t worry about this test. Just choose a trainer that takes a couple of hours to show/explain all the questions
As normal, John is absolutely correct SO FAR AS THE TEST GOES.
Interestingly enough, according to the latest VOSA guidelines, you’d actually be prosecuted for some of the above! So the best advice till DSA sort themselves out, is to do exactly as advised above but, when you start a job, get advice from an experienced person as to how the load should be positioned in the real world.
Best of luck with it and don’t let my comments confuse.
Pete :laughing: :laughing:
Cheers guys apprecate it :smiley:
