Well I sat my module 2 today and what a JOKE. I passed.
I thought these were scenarios we might encounter in our job as a lorry driver?
Billy fits secondary spray suppressors to his lorry.
What impact will it have on the road.
A. rubbish
B. even worse
C. will prevent grit and water being lifted from ■■?
D. Crap
I’m not bothered what he does!!!
When should the 5 gear be serviced.
A. 1 week
B. Month
C. 2 weeks
D. ?
I’m not bothered, as I’m a LGV driver.
Questions on tacho such as when is next break due if started at 5h30. Walk around check till 6h00, 15 min at 8h00 so when is next break due.
Stuff you get shown on CPC and deal with every day.
2 man owner and defective wheel with VOSA. Who is responsible? Both
Another stupid question: VOSA find a defective bulb. What do they issue? Well depends on if it is day or night and VOSA are not going to be such [zb]s as they will let you get into your cab and pull out your spare bulbs and replace.
2 Man driving. What do you set other driver to. Other work, available, break or driving.
Sue is a first aider and she comes across a accident. What should she do.
A. drive on
B. pullup in a safe place
C. ?
D. ?
Its raining. What distance should you drop back to.
A. 2 sec
B. 4 sec
C. 8 sec
D. 10 sec
On a motorway, what is the safe distance to follow.
A. 2 sec (only a fool breaks the 2 sec rule)
B. 4 sec
etc, etc
What would you restrain metal lumbar with.
A. Rope
B. Chains
C. string
D. ?
A load question with 4 pictures. The evenly distributed 1 was ticked.
Billy buys a 8 wheel tipper 25’5 Ton. He had a 18.8 Ton. How much more weight can he carry.
A tail lift has a max capacity of 2500kg. A crate weighs 1 ton. How many can be put on the tail lift? Anyone who puts anything other than 2, should replace the peanut who wrote this stuff.
What locking mechanism would you use on a container■■? Tough 1 so I guessed twist locks
Lastly when in your cab what would you apply before getting out- Handbrake obviously.
Last, last promise. Billy is on a ferry. What should he be supplied with.
A. rubbish.
B. worse rubbish
C. A couchette or bed.
D. rubbish.
Trivial stuff like that. I would not even worry about it as I feel what you learn on CPC counts more and the person who put all this together is a Peanut. It’s only the government and driver trainers making the money.
This is by no means personal, just vetting some of my frustration at the lack of knowledge and thought process that has gone into this module. If I’m going to spend £30.00 please let me learn something valuable.
