Dont want to over sleep,it is a Samsung Monte gt s5260,i have tried all the menu`s and the sound is on,but testing the alarm,it does not make a sound,it only lights up the screen,which is no good at 3 am.Any techies on board■■?
go into the alarm function where you set it etc then go to the setting bit and check what sound you have set the other thing is do you put the phone on silent mode over night as i had a samsung that if was on silent alarm didnt make a sound if your still having probs let me know ill try and help failinf that nip into phone cell in frome up between hsbc and lloyds one with little stream down the middle its on right hand side ![]()
Try turning up the volume either in the alarm settings menu or when the alarm is going off using the volume buttons
Thanks guys,i will try that,the Orange shop in Trowbridge is shut on sundays,and its 25 pence to phone the help line,i used to live in Cheap Street,years ago,bit noisy with the weekend drinkers at night and early mornings.
25 pence i can give you an advance on your pocket money
be crafty with the options on ringing orange if you ring and go through a card top up but enter wrong number you will eventually get put through i used to do this every time without fail though now on o2
The sound can be on full but if you don’t go into settings and actually set the volume for the alarm in paricular it will just remain silent. There are usually volume settings for incoming calls, messages and alerts, alarms should also be a seperate setting.
If that doesn’t work or you still dont trust it, buy a cheap alarm clock at a truck stop ![]()
post your phone number on here toby and what time you want a shout I’m sure somebody will ring you to wake you up
Yeah ! … post your number on here for hundreds of guys to see, we could do with a good laugh ![]()
