bubsy06:
Conan the Librarian:
ajt:
The light going out when you close the door thing must be in the settings as mine doesn’t do it.
On the lighting front, my dash clocks always default to dim no matter what level you previously had them at. Probably a setting thing as well but haven’t been able to find it.Pulling power is garbage.
The door stays don’t stay.
Zero traction. Can spin with 44 tonnes on. Gets stuck at the sniff of uneven ground.
Gearbox and engine don’t interact. Mine has a habit of changing up a gear even though the engine is pulling up a incline and revs dropping off. Dont even mention pulling out of junctions or randomly dropping into neutral sometimes.
Lockers are too high.
Seat doesn’t go far enough back unless you lift the bunk.
On the plus side its very high up, decent visibility and roomy cabs.
On your first point, mine does that too, damned annoying! Any idea what setting it will be to change it? I’ve looked and can’t see anything
There is a button up top that has a picture of a light above a side on view of the cab, push it until it beeps and that will deactivate the interior light auto shutoff.
You’re a star, thank you ![]()
