Hi chaps I’ve noticed today that only the 24v at the radio and the 12v at the passenger side footwell are working,the other 2 points are not.
Any idea why and any info on how to fix it?
Cheers
Pentland Loyal:
Cheers
Prob blown fuse
Ours keep doing that as the drivers overload them using kettles etc
nick2008:
Pentland Loyal:
CheersProb blown fuse
Would that not blow them all tho?
Pentland Loyal:
nick2008:
Pentland Loyal:
Ours keep doing that as the drivers overload them using kettles etcWould that not blow them all tho?
No as 24v one by radio is switched and 12v runs from separate dropper
They are not “fused” they are ECU controlled.If you try to draw too much current the ECU locks them out.
Most common fault is the the ground tang has burnt or bent and you have to strip the plug and repair it or fit a new socket.
Bking:
Strange why you say that when I had to change a fuse to get the switched one working when I took truck over
also there’s a 25a fuse for the 2 unswitched ones
