how do you change the bulb in the marker light on top of the cab on a 59 reg 85 cf ?
hyper26:
drive under a low enough bridge to bring the marker light (and roof) down to a level suitable level, your are forbidden to use a ladder so h&s says. IMPORTANT: make sure bridge is low enough to cleanly take roof off so not to smash the light upon impacting the bridge.
use crow bar to pry out the 2 nails holding bulb case in position - replace bulb in top marker light and use duct tape to secure light back onto roof.
while standing on a work colleages shoulders carefully align the sheared off roof and wrap duct tape around the cab to join roof back onto cab,.
paint duct tape to match the body work to avoid any akward questions from VOSA.
HAPPY TRUCKING
theres a few diffrent marker lights fitted to them…but it will either have a philiips screw on top which you undo and the plasic bit with the clear glass will pull off upwards or if its the rubber marker the lens pulls out of the plastic.check the bulb is 12 or 24 volt.
jayeastanglia:
Almost certainly be screws, and 24v
i could be wrong (like normal!
) but i thought the new ones had LED’s fitted? Still to new for us to be working on at work yet!!!
new to my boss is 04 with 700000 kms on the clock, just been run in he wud say
greasemonkey:
i could be wrong (like normal!![]()
Ooops thought it was 55reg not 59
Would have thought it was LED certainly under warranty take it back to the main dealer
scotstrucker:
So that’s where our old trucks end up.
Dealer job they have to take the lockers out to get access. I think it takes about 3 hours or so. I know this from expierence. Nobody including the two fitters who tried to prise,then unscrew the lens could believe it. We had only had the unit three weeks when the thing blew. So much for progress.
you cannot change the bulbs…have to replace the complete light…and ours are 58 plates.
john_london:
yeh this is about the same 3 months i looked at the lockers and your right u would have to remove them what a stupid idea that is
tofer:
scotstrucker:
new to my boss is 04 with 700000 kms on the clock, just been run in he wud saySo that’s where our old trucks end up.
Ive always wondered where old Norbet Dentressangle trucks go - you dont see old ones on the road
