Does anyone know how to remove the battery cover on the above model so I can get to the terminals ![]()
Forgot to say, this is on a 13 reg so the latest model. Looks complicated ![]()
mikeshe:
Wtf would you want to ![]()
To get to the batteries.
Scanner:
To do what.Hot wire a cb . . tv,lawnmower.
Its a 13 plate ffs,dont ■■■■ about with it - get somebody that knows what thier doing ![]()
Suedehead:
Scanner:
To get to the batteries.To do what.Hot wire a cb . . tv,lawnmower.
Its a 13 plate ffs,dont [zb] about with it - get somebody that knows what thier doing
Love the thought of a lawnmower running off the truck batteries, maybe doing a bit of roadside gardening as a random act of kindness. ![]()
Scanner:
Suedehead:
Scanner:
Its a 13 plate ffs,dont [zb] about with it - get somebody that knows what thier doingLove the thought of a lawnmower running off the truck batteries, maybe doing a bit of roadside gardening as a random act of kindness.
Now theres an idea,park in a lay by . mmm that grass could do with a cut.
On with the safety goggles in case you hit one of them there bottles of pish!! ![]()
Try putting a pic up, normally two clips at the bottom but not been loose on a 13 plate yet
Own Account Driver:
The only sensible answer.
To the rest of you…FFS I asked question that’s all. Why has sod all to do with you really does it? But let’s just say you needed a quick jump start one morning… nice to know innit ![]()
if it is the same as the TGA, there are 2 clips with D rings on them, twist them anticlockwise, then pull the cover off keeping the front edge low
shuttlespanker:
Thanks for that. I’m away for a week now but will have a look when I’m back.
mikeshe:
Own Account Driver:
Try putting a pic up, normally two clips at the bottom but not been loose on a 13 plate yetThe only sensible answer.
If you can’t work out how to remove the battery cover, make sure to price a new main ECU before you start interfering with electricity, good man.
