Hi,
I have a 2013 MAN TGS that is coming up with a abs fault when a trailer is plugged in.
Disturbance on Trailer ABS in Pin X/2
Trailer and lead are fine they work on another truck.
Before I spend time/money to investigate further has anyone seen this before? Any suggestions on where to start?
The pins on the abs plug are all clean.
Cheers,
Nick
If it ain’t the lead it must be the lorry,take it tofitter
Have had similar problems…abs lead iis ok on some trailers but cause problems on another…if its an orange light i was told to ignore it…or you could try someone elses lead to be sure…i was told some trailers use a different amount of pins in the leads…if i remember rightly its a 6 and 7 pin lead…some work others dont…good luck.
manualsdir.com/manuals/58354 … ml?page=30 look on google there some info on different trailors
bowers340:
Hi,
Cheers,
Nick
I had the same problem it was the older unit and new trailer not recognising each other , try it on a older trailer , fitter said everything works fine it just doesn’t recognize the newer trailer.
M
Sent from my ONEPLUS A5010 using Tapatalk
Sensor problems (causing the common, epilepsy inducing warning light circus on the dash) are a build in feature of MAN trucks. There is a quick and easy fix to this common problem with MAN tractor units. A can of petrol and a box of matches…
the nodding donkey:
This is one of the first faults ive had with this truck, been a magnificent truck
