Have 18reg man tgm .any one know how night heater works or more specifally where the little dial is to control the temperature?
Has inbuilt unit thing with controls for heater aircon
etc.
Have found button to turn it on.
But how do I change the temperature?
Have read the handbook. Which ain’t much use.
It says turn the dial.
But I can’t find it unless I’m missing something
How is the standard heating temp controlled ?
If done by left hand knob , then use that
If done by + - button and temp is displayed on screen then use that
blue estate:
Heating works by + - buttons. Press them and a series of bars show up showing how powerful you want it.
Temperature is just a big usual heater dial turn it from red to.blue depending on how hot you want.
So I take.it I just turn the dial up then?.
Handbook tells you turn the little.dial shows you a pic of a standard little.panel with a small dial type usually see near the bunk bit I can’t see it anyway.
Unless manual is just a generic man manual
edd1974:
blue estate:
They ain’t had that older type of night heater since 2010 ish
Yes turn the dial up
edd1974:
Ok thanks I’ll try that
Did you get nice n toasty in the end ?
Yes it seemed to work took ages to warm.up.
Although wasn’t best sleep ever had bed in this man ain’t that comfy. Stupid foam. Like mattress…prefer daf I used to have with a kind of proper matters in it
