Man tgl 7.150 abs fault
Hi could anyone tell me where the abs valves front axle are located on my 2007 man tgl 7.150 as I have fault code 03139-03 says abs valve front axle I have looked and looked and can’t locate them any advice would be great thanks
Follow the airlines back from the hub.
I have they go straight into the valve block under the front flap brake pedal block cheers
The abs valves are built in to the foot valve.
Thank you af1
Af1 can I just straight swap it out or do they need to be coded cheers
Jimbo533:
They need programming. I would get it checked out first to make sure it’s 100% a faulty foot valve before replacing as fault codes alone can only point you in the right direction and those valves aren’t cheap.
