Been off for a week get back into my unit and the buttons on the steering wheel no longer control the radio they still control the computer so it can’t be the buttons themselves at fault can anyone shed some light?
Thanks in advance
Thanks in advance
if you go in to the main menu, there is a setting for tractor unit or audio
have you tried selecting the audio option?
Yes it won’t let me but it will let me into the tractor one
Just been playing with mine, should let you into audio, then comes up with traffic program
Audio display
Radio
Cd
Audio off
Can you highlight ‘radio’ then ok it.
If you can’t get into that bit I think maybe someone has Spanked your buttons !!
martinviking:
Audio display
Radio
Cd
Audio off
oh, so, now you’re blaming me
shuttlespanker:
martinviking:
Audio display
Radio
Cd
Audio off
If you can’t get into that bit I think maybe someone has Spanked your buttons !!oh, so, now you’re blaming me
Nah if that were the case it’d of been nicked
Has someone connected a mobile phone to it whilst you’ve been away, because according to the manual page 309, using the MAN hands free system uses the same buttons on the steering wheel.
shuttlespanker:
martinviking:
Audio display
Radio
Cd
Audio off
Sorry, didn’t mean it that way !
All the buttons still work I can use them to get into the options for the tractor to check oil ect but it won’t let me go into the audio option
Is it still displaying the radio station name on the dash? If not, then I reckon the CAN wire has become detached from the back of the head unit.
damoq:
I will check it out thanks mate
Everything seems connected to the back of the radio, just to add its a tga xxl
Joycey:
My 56 plate TGA used to do the same thing regularly if i was playing CD,s in it ( didn’t happen if i was listening to the radio).
Pull the radio out using the 2 metal radio removal tools ( if you have not got any they can be made easily with welding rod ).
Disconnect the power plug on the back and reconnect it ( will lose the radio presets),
This should solve the problem , don’t know why , but mine used to do it every couple of weeks.
dingo:
Joycey:
Everything seems connected to the back of the radio, just to add its a tga xxlMy 56 plate TGA used to do the same thing regularly if i was playing CD,s in it ( didn’t happen if i was listening to the radio).
Worked like a charm thanks a lot
