Hi guys,any of you drive a MAN and have had problems with drivers door not closing. Fitter in depot says its a common fault and he can’t do anything about it. Any ideas
the early versions had a problem where the hinges would start to break away and the door would effectively drop a touch causing allsorts of bother shutting them…the fix at the time was a plate welded around said hinge to strengthen it all up…im going back to 02/03 as where i worked had a fleet of them and 90 oercent suffered this…might be that
