Lorry driver follows sat nav oops
robroy:
idrive:
Here’s how they get them out.
youtu.be/au-5CGoYtQs
Nice lift by the crane driver.
A toot of the horn, a polite round of applause, and the chips are on their way!
Whereabouts in Cornwall is that exactly?
(So I know to avoid it :blush: :smiley: )
Plymouth somewhere if I recall.
raymundo:
Was the bloke in shorts but no hi vis with a phone in his left hand waving his arms around the driver ■■ I couldn’t see if he was wearing flip flops though …
I assumed he was the house owner as he seemed to be pointing at the damage, although I suppose it night have been the driver moaning about the house being in the way :laughing:
carryfast-yeti:
idrive:
and then wait for the hefty bill from the crane operator!
Probably quite reasonable compared to the bill from BT or whoever it was moving those cables :unamused:
robroy:
idrive:
news.bbc.co.uk/2/hi/uk_news/engl … 086989.stm
Forder Bridge near Saltash apparently.
“The driver managed to avoid a crash by slamming the vehicle into reverse when the brakes failed” :exclamation: :bulb:
idrive:
Ironic it says eat more chips isn’t that how you can get stuck in tight spaces.
idrive:
robroy:
idrive:
I’m surprised that Juddian has not used this as a prime example why manual gear boxes are superior over automatic…
SJB:
It does
Yeah but if you muck up the independent drive and keep going wrong, it’s not a fail, I don’t think it’s even a minor.
Don’t ask how I know :blush:
It is a fail. Don’t ask how I know :blush:
Driving test: cars: What happens during the test - GOV.UK
Going off the route
The examiner will not give you a fault for taking a wrong turning.
They’ll help you get back on the route if you do.
INDEPENDENT DRIVING FAIL
During the independent driving section, you will not fail for making a wrong turn, but you may fail if you become excessively stressed and panic to the extent that your driving becomes affected.
My examiner explained that although I messed up pretty bad (had to do a tricky turn in the road on a busy road to get myself out of it), as it was done safely it was still a pass. (I knew he’d be watching me like a hawk at that point, so I tried my best to not screw up any more than I already had) :laughing:
If you commit a serious in the process of going wrong, or at any other time, then of course you will fail, but being useless at following directions or navigating via the roadsigns isn’t a fail in itself.
There’s obviously an element of luck to it. If you took the wrong exit on a roundabout by mistake then it’s not even a minor, but if that exit has a 7.5T prohibition as you enter, then it’s a retest!
