London dridges help
Got a delivery into Clapham in the morning, going to be coming in from A4 and over the river.
I can’t remember which of the bridges has the 3t and 6ft6 restriction on it. Can any one help?
El Deano:
Last time i was in that neck of the woods I came off at Hammersmith Broadway, down Fulham Palace Rd and over Putney Bridge through to Wandsworth via Putney Bridge Road. Running at 14ft.
The one with the restriction is Battersea Bridge. If you come off the A4 via Cromwell Road and then chuck a right down through the opposite side to the old Earls Court into Edith Grove eventually, then crack on down till the river, first chance for a right turn is Chelsea Bridge, turn right over this and down to the roundabout then onto into Clapham. You will fit under the bridge to the left if you need to head down to Nine Elms Lane and along the Embankment south side or straight on to the lights, straight on into Queens Road will bring you to the Wandsworth Road then up to Clapham Common.
Hope this is of some help.
Need to add the Albert and Hammersmith bridges as prohibited. Both have been no go for many years but now Hammersmith is completely shut including pedestrians and river traffic passing underneath, even the tow path underneath is closed.
I always used Chelsea Bridge,when coming in,on the a4.
