I could do with a bit of advice as over the weekend I drove my first 6 legger unit with a lift axle
The question is - How do I know when to lower it
I noticed the control button on the dash but I didn’t know if it lowered automatically or if it was somehow determined by the weight of the trailer and needed to be activated by me?
As Rog says, just have a play in the yard before you go out next. Believe most will drop automatically once its got a certain amount of weight on.
Remember to lift it though when empty to save tyre wear. Also its not a good idea to run in the wet with it down when empty either.
Chopsticks:
Cheers Chopsticks I’ll give this a go next time I use one - I did press the button in the cab to see what happned and the axle did start to lower, but I was usure if it was lowering because it needed to due to the weight or if it was just going down anyway??
I guess for any new driver without knowing how to use these axles we risk having an axle overweight dependant on the weight of the load?
Anything made recently (less than 5 or 6 years old or something like that) and many older vehicles too will drop the lift axle automatically when the weight on the drive axle goes above a preset amount. Generally all you need to do is remember to lift it back up again when you’ve tipped your load. You’ll soon get used to how they work.
