Licence for hgv recovery truck
What licence is needed for recovery trucks that rescue lorrys and buses? The sort of work that neil yates for example use. Class 1 or 2?
Dan
AlltypeArocs:
Dan
Class 1 probably as the busses you are towing will definitely weigh more than 750kgs.
True. I just wondered if there was any kind of dispensation for a recovery vehicle.
AlltypeArocs:
Not sure if there is any dispensation for recovery as I worked for the AA a few years ago and you needed to have a class 1 licence for the reasons I gave before. Maybe it was just an AA rule and not a legal requirement though.
If you are recovering cars/vans on a tilt and slide, possibly 7.5, probably C
If you are recovering cars/vans on a tilt and slide, with a spec lift, C+E
Heavy recovery, C+E, unless you are in Scotland, then C
SWEDISH BLUE:
Would someone with the old class 2 with 102 restriction be able to drive say an 8 wheeled wrecker towing a full 44ton artic on there licence or would they need the ce without 102,seems crazy if they could,but couldnt drive the artic on its own but could tow it!
SWEDISH BLUE:
C+E (class 1).
Go to page 24 for Driver licensing , hth :wink:
:Guide for recovery
operations.
gov.uk/government/uploads/s … ations.pdf
^^ is that not what I said ? :smiley:
SWEDISH BLUE:
I just thought it would be a grey area with a ce 102 coz u coud almost say the combination came into a drawbar ie wreaker with artic behind it!
SWEDISH BLUE:
You did say that yes :wink:
I just added the info link for ya `n ’ im :wink: yaar .
echo
echo
echo
:grimacing:
SWEDISH BLUE:
Why not in Scotland
