I have volunteered to help restore a 1989/1990 Leyland Freighter 13.13 cherry picker for an aviation museum. Overall it is not in bad shape, with just some patches needed on the cab at the normal places.
Now, the bit of hello need is on starting. I am not sure of the engine yet, but I am told it once ran out of fuel. It has since been bled, and does run, but only after easystart is used. What could be causing this? Doesit need re-bleeding? If so, where are the bleeders?
Sounds more like the initial ignition is struggling, your getting fuel by the sounds of it, maybe it’s dirty or has moisture in it, I’d have a full fuel line purge.check the tank, then start checking the electrics
Why not put a fuel line into a 5 gallon drum full of clean deisel,When bleeding it make sure the ignition is turned on, also what engine has it got in ?, Regards Larry.
