Can someone please kindly explain what this means please. I’m trying to figure it out but my imagination is running wild with all sorts of possible situations and scenarios. cheers
instantKarma:
Reversing an artic on the drivers side
Moving the steering wheel to the left will bend the trailer to right
Once bent, moving the steering wheel to the right will bring the unit back into line with the trailer
doing a blindside reverse the saying is the opposite
I take it it’s a minor if you steer the wrong way?
Not if you steer left to start with as the trailer runs over the yellow line
Also steer into the side you want to straighten , same as above just a different saying you’ll be fine take it slow
