Looking to put some LED lights on the front of our Scania. What are people’s preferred way to wire them up to the side lights. TIA
It’s not how I’d do it as a pro job but if you just want them working fast just scotchlock into the nearest sidelight wires providing they’re a fairly modest current draw.
Generally if the wire on your one is no thicker than what you’re piggybacking on it should be fine. In case you are unaware they will most likely have polarity so you need to check and see which way round the wires need to be for them to illuminate.
