Lampeter. Wales
Thurock to above in an artic best route any thoughts thxs
p m switchlogic i’m sure he lives out that way… hth
bjd:
Well the route to south Wales is straight across the m4 the problem is getting to lampeter if your loaded and on your weight go up the a40 upto landovery it’s not a bad road if your light run down camarthan and run up the a485 but I think the first route is the best
Sent from my SM-G975F using Tapatalk
glynn.woodward:
bjd:
Looked at M4 then right at Newport a4042 then a40 but wasent sure not done much that way will be 44t
bjd:
glynn.woodward:
bjd:
No bottom way is better mate I use to run 18.5 meters girder to landovery it’s a better way than goin up towards merthyr tydfil and going over the rhondda road
M4 down to carmarthen then?
m.a.n rules:
I do indeed I live in that very town. M4 to Carmarthen and up is only sensible way
glynn.woodward:
bjd:
Disagree, going via the A40 and Llandovery is just extra work. M4 to Carmarthen and up is best route empty or loaded. Yes the odd hill but nothing too critical. You can’t avoid hills out here anyway
switchlogic:
glynn.woodward:
bjd:
[emoji106]this is what I like about this site always someone to help out thanks switchlogic if you know you know[emoji108]
Thank you everyone appreated
glynn.woodward:
switchlogic:
glynn.woodward:
bjd:
And it’s it’s best when people can disagree like we have and be sensible about it as you have! Too many on this site seem to take disagreement as a personal attack!
Hi Glynn Woodward where in Llandovery did you deliver to ? Was to that nice yard you had to reverse down the hill and so much room you could land a plane NOT on the farm Mc Canns Engineering
ianto:
It was mate used to deliver barrett steel girders into there I think hall and roache did there European work
