Jwalsh8:
Afternoon,
I know your supposed to add the kerbside axle weights to your payload axle weights when working out your axle loading but how do you know what they are. If you know your kerbside weight is say 10t with fuel, driver, eggy vest and ■■■■ etc. How do you work out your kerbside axle weights for this?
Cheers
Jonny
Hi Jonny,
Below is a worked example, but it comes with a caveat…
This will only work for a 2-axle rigid, because the calculations for multi-axle rigids and artics are quite different.
In this example, we know that the vehicle weighs 8,000Kg with you in the cab and when fuelled and ready to go.
You know this because you went to a weighbridge and got a weight ticket when you had a full fuel tank and with you sitting in the cab when they weighed the vehicle. ( = Kerbside weight.)
We also know that the vehicle is allowed to weigh a maximum of 18,000Kg, cos that’s written on the vehicle plate in the cab.
We have measured the distance between the axle-centres and found that it is 5 metres. ( = Wheelbase.)
The sender of the goods has promised you that the load weighs exactly 10,000Kgs ( They never tell lies.
In this example, the load is of regular dimensions and density.
Method
Measure the length of the load and find the center of gravity.
(It’s the blue spot in the centre of the cargo in the picture)
Using the dimensions I’ve added in the picture, we can now apply the formula as follows:
“P” = Payload (10 Tonnes) multiplied by “D” (2 metres)… so 10 X 2 = 20
“D” is the distance from the rear axle to the imaginary line downwards from the centre of gravity
Now divide the 20 by 5, (the wheelbase) which gives you an answer of 4 tonnes imposed on the front axle.
Therefore, the load imposed on the rear axle is 6 tonnes
You chose to use the dimension from the rear axle to the centre of gravity, so the 4 is the weight (in tonnes) imposed on the front axle.
If you took the dimension from the centre of gravity to the front axle the calculation would be
10 X 3 = 30
30 divided by 5 = 6, so the load imposed on the rear axle is 6 tonnes, therefore the load imposed on the front axle is 4 tonnes.
It doesn’t matter whether you use the forward OR rearward dimension for your calculation, please remember that the answer will always be for the other axle.
Once you know the answer to that, the other axle is carrying the rest.
The above is highly theoretical, but it will give you the basis to make adjustments for use in the real world when you need to use your judgement for irregularly shaped loads, or machinery which is heavier at one end than the other.
I hope this helps.
