I drove a Stralis recently and also found it very comfortable, particularly as regards lateral stability (in the seat).
It did seem very slow getting away into roundabouts, but a Johny explains, this may be because of the way it was driven from new. With the load(s) I was pulling it was selecting 3rd to move off and so I simply changed to semi-auto and nudged it up a gear, which helped.
I especially liked the feature where, after removing keys, you can knock the power back on for the radio and windows.
On the other hand, I had an “R” series the other day. I couldn’t get the seat high enough to get my feet flat on the floor, and neither could I stretch my legs out. It was one of those 9+ hours driving days and at the end of it I felt like I’d been sitting on a toilet all day. Terrible. The gear lever could also be about 3" shorter.
The gap between the nearside mirror and the A post is too small. Easy to ‘lose’ a car or motor cyclist when turning right into a main road. And the A post seems bulkier than on the 4 series.
One good point is that the Hazards switch is now by the door, with the bonnet release actually within the driver’s door aperture. Perhaps someone from Scania did take note of posts a couple of years ago regarding layout design and vehicle checks. (What is the point of having to climb into a vehicle to switch everything on, only to then have to climb out again?). But why have they attached the quarter panels to the bonnet? I walked round and nearly banged my head on one. And being one of the most frequent body panels to be replaced, this arrangement will be costlier to repair.
The switches for the ancillary lights are hidden behind the steering wheel and I NEVER did manage to work out either the heating or air conditioning controls.
The configuration of the cruise control switch baffled me somewhat. A double-action rocker switch set into the lower portion of thesteering wheel. Press top to set or increase speed. Bottom to reduce speed. - reasonably logical. Right side to disengage, left side to Resume.
Surely it would have worked better when thought of as a light switch and the relation of pedal configurations.
Press the top for Off. The bottom for Resume, Right to Set/Increse (as per accelerator pedal. Left to Reduce speed. (Brake pedal being left of accelerator). - Except, of course, some Countries operate their domestic light switches the opposite way to ours.
In the dark, the outline of other dash mounted switches merged into the background. Instead of being able to locate the outline and ‘feel’ the switch, I was forced to identify the symbol and then ‘stab’ at it whilst hoping the vehicle did not hit a bump in the road.
The action of the indicator switch was very smooth, engineered rather than just sprung plastic keeping it on, although I did find that the self-cancelling came into effect too early which meant that minor corrections of the steering resulted in the stalk having to be re-engaged.
Overall - not impressed.
