Does anyone no if the Iveco Eurostar 03 plate has a flat floor cab
If I remember rightly, the Eurostar was never truly a flat floor cab. There was a document box thingy between the fridge/coolbox in front of the bed (both can easily be unbolted and removed) and a triangular sticky out bit of the dash but it was more than strong enough to stand on and there was plenty of headroom in the high cabs.
The main downer I found was a lack of lighting in the high roof line, couldn’t see onto the top bunk never mind into the cupboards. Easily fixed that with some extra lights tho’
The bottom bunk is much colder to sleep on and suffers from drafts from the outside lockers. Look at plugging the gaps if thats your preferred sleeping place.
Bit on the cheap and plasticy side but with a 520 bhp motor and auto gearbox, it was quite a tool and easy to drive!
no it isn’t, theres about a 12" drop from the middle into the footwell
