I have a 63 plate Man tga and I’m putting a 24v inverter in for my microwave. Does anyone know where the cables run through into the cab from the batteries or if there’s a sufficient supply already put into the cab for such uses. It’s got to be a substantial supply as the inverter is a 2000w one. Thanks for any replys
You’ve got to wire it straight from batteries , no suitable connections in cab
Is it a tractor unit ? If so just get an Anderson plug same size a tail lift socket and run a wire from there
blue estate:
Is it a tractor unit ? If so just get an Anderson plug same size a tail lift socket and run a wire from thereSent from my iPad using Tapatalk
I’ve just this week had a 3500 watt pure sine wired into my MAN, it’s wired directly to a point in the fuse box using (to be technical) big eff off cables. I must add that our garage did this as the sum of my electrical knowledge is "red to red, yellow to yellow, blue to ■■■■! ![]()
I thought there must be somewhere in the fuse box to go off so I’ll have a look tomorrow many thanks for that if not plan b will be in motion lol
