Inverter help
Will a 150w 12v inverter run a TV with a rating on the back of 50w. I’m thinking it will just about do it.
After a quick search on here 150 may just be enough.
I`m no expert but, if in doubt go bigger. More likely to last longer and still useful if you change for summat with bigger power demands.
Of course it will work it’s 150w and the tv is 50w.
Not like 20 yrs ago when volt drop, heat, and technology screwed it up.
As some say, bigger is better, and i have found that a bigger one can even be cheaper than a smaller one…just saying.
I used to run an xbox 360 slim and a 19" tv off a 150w inverter!
It’ll work but it’ll probably struggle and potentially burn out the wiring. You’ll feel the wire get hot.
