hi my old inverter has finally given up the ghost and has gone in the bin as it was continually blowing fuses. im now looking for a new inverter that can be plugged straight into the 24v socket supply then eventually it will be hardwired by workshop later on. can anyone reccomend a decent one that will last a few years.
cheers
33 views and no one has any advice on inverters.lol
I use a 300 watt inverter,runs off the anderson lead and powers laptop/tv/powered speakers. not sure what make but would run equally as well of 24 volt plug in cab, make sure its a “soft start” but as to make type etc just choose one you can afford. mine cost £20, dont get a 12 volt one and 300 or more will be adequate except for running a microwave.
I had a ring “can” inverter that plugs into 12v socket. Ok for running laptop or ipad, but i think anything with a bigger wattage should be wired directly to the battery.
