In cab ■■■■■■■ when double manned. Is this right or wrong in your point of view, should be thing of the passed like double clutching or night of the road side graffics ?
Maybe Only ok if after you have shared a cab afew times ? fine if you ask befor doing it.
Ever try the sly it out the slow way and hope the other wont notice, more orcward when lady in cab or harder still the boss of company ?
ever done it by accident loadley and felt embaraced after ? Worser still followed throw with it ! Ever had to pull over and leave cab its smell was so bad, even if it was your own ? refused to double màn with some one because you knew thay were bad for it ?
Only genuine Thoughts and feed back on this one. would be good finally get some ground rules on all this. Thanks
I’ve was double manned before with this one guy,went out for a big lunch before coming to work, jesus on the way to first delivery he dropped one, it dried the water out from my eyeballs and sinjed the hairs up my nose, it smelt hot,and the taste was no better, wound the window down and drove a few minutes, test sniff smell clear,ok window up, i gave him the look of death, and said how offensive it was,he just gave me a awful smile from cheek to cheek, few more minutes later, boom, i thought we had a blow out, i look over hes got a smile like the grinch, pleased with himself, i wound down the window stuck my head out,caught a glimpse of my self in the mirror, my eyebrows had melted off my face, even stink would say that stinks,.
1st delivery done,i locked the cab with me in it,he came back trying to get in, i refused until he had gone for a dump, stuck it on 15 amd said, u got 15 minutes to clear out or im leaving you here.
True story.
Scott88:
True story.
Good shout Scott 88, thanks for the feed back. A vote for its no longer acceptable I think !
It’s one advantage working on sewage tankers,I just let em go…
Hmmmn. A dangerous endeavour if you ask me.
The problem is escalation. If you try a sly ■■■■ hoping it won’t smell, and it does, you have drawn the battle lines.
And already lost the element of surprise. Which was your trump card.
I was once travelling as a passenger in the back seat of a Fiat 500 and as I’m six foot four and sixteen stone I wasn’t happy to start with. When the driver let one go that smelt like the gates of hell had been opened and proceeded to close the windows I became distinctly less happy, in fact if I’d been capable of the movement required to extracate my phone from my pocket I would have phoned the police!
Best to ■■■■ and smell a bit,
than hold it in and have a fit.
Often my drivers’ mate was agency so post ■■■■■■■, the cab smelt no different.
My main problem is singing. I start singing really loud and dancing a bit, then look to check I’ve not forgotten that there’s someone else in the cab
I was double manning once and me mate pooped himself. Worst spitroast ever. Specially as I was taking my turn in the middle.
depends on the type of ■■■■. the last thing you want to do is ease springs then have to check your underwear for a negligent discharge
