Just thinking ahead here really, the other day I put my card in the tacho and it seemed to struggle to read it and after a wipe and a few ejects and inserts it eventually did. Could well have been a one off but I’m just wondering if the situation came about that my card couldn’t be read for some reason, do I do a printout there and then without my card in and just fill duties etc. on the back with a pen as I go along, or do I leave that till end of day?
I would obviously look to get a new card if it happened more than once. Cheers
Do 2 printouts at the time sign the back and explain.
Then continue to use the tacho unit as per normal changing modes etc. At the end of shift do a Further 2 printouts and sign licence no etc as you did for the 1st starting printouts. Keep 1 set for your records and hand the other to the office
nick2008:
Just to add by doing this there’s no need to black line the printout
Thanks mate. At the start of the shift and I select print out, do I leave it on the 24hr option and press ok? and the same at the end of my shift, cheers.
andy_s:
Yes it’ll show the date i.e. 5/3/2017 ok
Then 24hrs ok
Print
The the same for finish of shift
The only time you show a different date woul be going past midnight
