eddie snax:
The thing is Carryfast, there is no need to use the lead up ramps, there is no grease or scuff marks on my lead up ramps(yet) and I haven’t shot the pin for decades(1 of those novice errors you vow not to repeat). I have a fully auto 2 pedal Scania, with careful use of the manoeuvre mode, there is no need to thump under the pin either, you should be skillfull enough to line up and lower the fifth wheel to drop under the rubbing plate then lift and push onto the pin with a gentle click, give the pin a tug to confirm connection, and at that point exit the cab. None of this getting out to check, granted if your in different motors all the while, then that’s ok, but if you drive the same truck all the time, you should know its size and ride height, and be able to work out whether a trailer is to high or to low to get under as you approach, and if you don’t, how are you going to drive it out the gate
If I’ve read it right you were referring to the method used with steel suspension.In which case there was obviously no way of dropping the unit under the trailer anyway.On that note from memory I coupled up the DAF 85/95 on air in just the same way as all the older wagons on steel.In which case grease on the ramps was actually a good thing with the ramps being there for a reason.That being to lift the trailer as the unit was put under it thereby making sure that the pin was in the correct position vertically relative to the jaws of the fifth wheel before it was coupled.Therefore no risk of mis couples or over shot pins.All of which obviously being dependent on making sure that the trailer was dropped low enough.While any grease wiped off the fifth wheel onto the cat walk and lines was what the power washer was for.
Yes, in my earlier post I was bemoaning the fact that many driver have not had to use steel sprung units, and made the point about the need to allow room for spring compression when reconnecting to a trailer dropped empty, then picked up loaded, and as you rightly state grease was a good sign on the ramps. But now with air, and a bit of professional pride, there is no need to have grease other than on the fifth wheel. My other point being, that there is also no need to raise the unit from the road height position, as you will still have enough travel to lower away from the rubbing plate as you pull away.
When I first had an air suspension tractor(man 22.362) I would still operate as with a steel sprung tractor, partly because that was what I was used to doing, and partly because other still had steel sprung units. Which is similar to you with your Daf’s I suspect, but everyone has air, and its the present day method of working, provided its done right there is no issue, only when drivers rush or get complacent, or just don’t understand do you get issues
Talking of grease, it was not an irregular part of the ongoing driver responsibilities to top up the grease on the fifth wheel between services, this is something that never has to happen now. Every workshop, and most hauliers had their own, had a large drum off grease with a stick, or maybe it was just something that happened where I worked
Juddian:
I can only agree with Eddie Snax’s method, whilst i was in your camp in the days of steelies CF, even i have moved with the times
and make use of the air suspension to allow a much more gentle pick up…which helps keep everything nice and clean, and puts the grease where it should be.
Pick up ramps aren’t made like they were in the day of steel springs, they were solid jobbie made to run a loaded trailer up and down for years, if you did that with the thing we now have the bloody silly little bolts holding it on would sheer off.
Where Eddie and i differ is that because i’m on tanks, once i’m somewhere near getting the pin into the opening of the fifth wheel, i’ll get out and have a butchers, cos lining up a tank, unless it’s your own regular tank, isn’t the same as reversing under a square fronted trailer, with the best will in the world with a strange tank you can be a foot too far over, carry on and the pin will ride over the fifth wheel ■■■■■■ up one side…not good with a tank cos bloody easy to dent a bugger underneath if you miss the pin, and that’s going to cost serious wonga.
Like Eddie, the only pushing effort will be the last 3/6" when i raise the tractor suspension enough to lift the legs clear and drop her in…where mine differs is being Arsetronic it has an on/off switch clutch actuation so if its heavy it’s going to be a thumper even at 3".
I have often looked those narrow necks on tanks, and thought that would be difficult, and in those and a few other circumstances, I too would get out for a look. I used to occasionaly pull a cattle float, and that had fluted front corners, and was a pain to line up, so I would get out to check. Its all about a proper attitude
