How much trouble will I be in?
De. D
None…Don’t worry mate.
next time it happens
all you have to do
is press OK on the tacho (once or twice)
and thats the end of it
villa:
all you have to do
Correct, pressing ok makes all infringements disappear altogether. Also, if you click your heels together three times you end up in Kansas. :wink:
as far as im aware overspeed is not an infringement and as some one mentioned earlier you cannot be done on tacho alone for speeding,i have several overspeeds every shift just let it roll but check for smoky and the wheel tappers
Lots,
the incab satelite receiver will ping every anpr within a 1000,K radius and a bolt of lightning will rain a thousand camels down on you,
your [zb] :laughing:
the maoster:
villa:
all you have to do
:laughing: :laughing:
Click OK to get rid of annoying warning, get on with rest of your life.
I used to get tons of overspeeds every shift running downhill. Speed limit on motorways is 60, not 57, so every time I let it run a couple of MPH over the limiter up it came.
Conor:
exactly
let it roll down hills and do 63 or 64 mph
bearing in mind the ten % tolerance makes the limit 66 mph
so you wont get done
click ok to clear tacho warning
end of story
Just keep it lit !!
I got a verbal warning for doing 63
